Can pressure setting be changed on Remstar Choice LS
I have this older machine. I need to have the Pressure increased. Is this something I can do? Or does it need to be taken somewhere??
Thanks,
John Daniels
Это хороший вопрос?
Thanks,
John Daniels
Это хороший вопрос?
Jj Daniels you really should get those pressure properly adjust by someone in the BioMed field or rep for this device. Speak with your healthcare provider about that.
For educational purpose, there should be a small door on the bottom right. If you remove that, there should be a slot that says "Pressure" You would need a screwdriver to adjust it. There are no preset pressures and you would need a manometer to get the proper pressures. Again, have your healthcare provider assist you with that.
Был ли этот ответ полезен?
Thank you! I will take it to my provider. I would not trust myself to mess around with that stuff!
I have been looking for this Respironics Remstar CPAP’s for several years and would love to buy one!!! 865-850-5566
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 40
За всё время: 499
2 Комментариев
You need a new sleep study to determine what pressure level you need and they can adjust the level on the sim chip.
Sorry, I haven't checked mine out to see is you can do it yourself. But a new study will take care of the problem and tell you if you have a bigger problem than before.
из Norma Roberts
Yes you can change your pressure. I would love to buy one of these CPAP’s if anyone wants to sell!!!!
из Darren Nichols
