iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Any known methods for removing scratches from plastic screen
Hi
Iv have recently repaired and iPod classic 7gen but when the screen when is lit up you can see little rainbow scratch marks across the plastic screen and I am wonder if anyone has any know methods of removing these scratches
Any answers or suggest are greatly appreciated
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
There are commercial plastic polishing compounds. They come in various grades. I used them when I worked to refurbish electronic communications equipment for the disabled. Don't expect perfect results and work slowly and gently for best results.
Here is one example, which is NOT an endorsement just to give you an idea of what is out there.:
https://www.novuspolish.com/
Remember it is best if you contact the manufacturer yourself. Tell them what you are trying to polish and they should recommend their best product for that plastic. Use your own judgement. If they are too positive be wary.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks!
Il give it a shot
Thanks again:)
из
Наиболее полезный ответ
Hi @hellomacos
Try using a non gel type toothpaste i.e. ordinary toothpaste and gently rub some over the scratches and check if that works. Wipe off with a clean dry cloth.
Do not apply too much or apply too much pressure to the screen.
Also turn off the device when trying this.
Оценка 2
5 Комментариев:
Thanks
I will try that right away and tell you the results
из
Hi @jayeff
Sadly no luck but thanks sooooo much for the advise it is greatly appreciated
Thanks again:)
из
@hellomacos
Please unaccept my answer as it didn't work for you.
Cheers
из
Hi jayeff
I think I have unaccepted the answer
Your one has gone from “chosen solution “
“Most helpful”
Thanks again
из
Добавьте свой ответ
HelloMacOS будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 19
За последние 30 дней: 77
За всё время: 2,425
