The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
Вопросов 20 Показать все
How would you fix the left bumper?
The left bumper on my Series controller stopped clicking. The bumper now just squishes and does not record the button press.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Выбранное решение
I'd probably guess that replacing the bumpers would help. iFixit sells replacement bumpers here. There isn't a repair guide for this, but you can follow this disassembly guide up to the part where the bumper is removed, swap in the new bumper, and then follow the video in reverse to reassemble. If this doesn't work, your best bet is most likely just sending it to Microsoft for repair, or even just buying a new controller.
Replace your controller's bumper assembly compatible with Xbox Series X model RRT-00010 and RRT-00013 gaming consoles. Fix issues like a cosmetically damaged or bent bumper cover. Изображение
Продукт
Xbox Series X/S Controller Bumper Assembly
$9.99
Был ли этот ответ полезен?
Оценка 3
Usually just try to replace it (it's actually cheap and available) but if you don't have a good soldering skill you will have nightmares with it
Оценка 0
It’s is not pressing down correctly
Оценка 0
Добавьте свой ответ
David Evans будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 11
За последние 7 дней: 43
За последние 30 дней: 138
За всё время: 11,450
