Портативная игровая консоль производства Valve, выпущенная 25 февраля 2022 года.
B button catching and getting stuck on shell
Has anyone come up with a solution to fix this? I thought maybe replacing the buttons might work, but the only part you can buy right now is the button membrane, which doesn't help. The only solutions i've seen currently is to either put a piece of tape in between the button and shell so the button doesn't catch, or to open up the steam deck and sand down the inside of the b button hole so it's nice and smooth. Anyone had any luck with the sanding?
Это хороший вопрос?
Оценка 4
Добавить комментарий
Ответов (1)
Here is the link to the teardown if that is the route you want to take: https://www.ifixit.com/News/57101/steam-...
I haven't done it on the Steam Deck but have for other devices. It is also worth a shot to make sure when putting it back together, that it is lining up properly.
-Warren-
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Conner C будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 8
За последние 30 дней: 38
За всё время: 3,055
