I cant remove my playstion from safe mode and only shows red light?
Remove From Safe mode
Это хороший вопрос?
Это хороший вопрос?
Hi @bigbio
I can't gauge what you mean based off the information available so it might be a good idea to go to: Adding images to an existing question. However i can give you some vague advice:
Firstly, can you research and see what you find. I couldn't find anything
Then, maybe try the hard drive swap and see if that works (That's unlikely)
Do you get a display out?
Also, do you happen to be able to plug in a controller and interact with it.
If you try any option in the OSD, does it flash up an error?
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 19
