Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429вопросов Показать все
2011 iMac 21.5 inch kernel panic
Hello,
I have an iMac from 2011 that I acquired without a hard drive. For some reason, no matter what OS I put onto it (via USB) it kernel panics and restarts somewhere during the boot process. Once time, I got into the High Sierra installer, and something popped up telling me to restart, shutdown, or save something to a log.
Any suggestions?
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
For anyone else with this problem:
Turns out it was a bad RAM stick
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
Hi @gaussymousy
I haven't had any experience with this as i use an imac 27" (That has coloured bars on the screen)
Firstly, have you tried swapping out your hard drive? It could be faulty
Next, have you checked all your connections are firm and in place?
Finally, have you tried researching online to see if anyone else has had this issue?
Good luck,
Nick p
Оценка 1
Добавьте свой ответ
Gaussy Mousy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 66
