The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428вопросов Показать все
Why does my Xbox One S turn off immediately?
Note: I already replaced the power supply with a fully working one from iFixit (New) but it still gave the same result.
After accidently dropping my Xbox, it beeps and turns on for about 5 to 10 seconds then shuts off. I have a feeling that it's an issue with the hard drive as it makes a charm after the Xbox One S turns off, but I just want to make sure as I don't just want to waste money.
Update (06/02/2022)
Front Mother Board - https://imgur.com/a/rswPhrX
Now after viewing the backside, I was totally surprised to see how dirty it was. Water Damage? Now that I think of it, I think it's the motherboard which sucks lol.
Link: https://imgur.com/a/ucfK4ZW
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@xdstarr definitely some water damage. First thing you need to do is to clean that board. Remove the heatsink etc from it and get some high grade (+90%) isopropyl alcohol. Poor it in containing large enough for your motherboard and then soak the board. Use a couple of soft brushes and "gently" clean the board. You do not want to scrub it since that potentially could knock components of the board. You can use something like this guide Even so it was written for an iPhone logic board, all the points are still pertinent to your board as well. While you are cleaning it, you need to look for any burned, charred or missing components. Those can be replaced and traces can be fixed if needed. Post some good, clear, large pictures with your QUESTION after it's cleaned so that we can see what you see. Pay particular attention around area D9 on your board since that is where the power IC's etc. are located. Adding images to an existing question
iPhone Изображение
Инструкция
Repairing iPhone Liquid Damage
Сложность:
Сложно
1 - 2 hours
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Был ли этот ответ полезен?
Оценка 1
i see a lot of red flags man can u show me the bord Cuz it could be its not getting power or a component on the bord could have broken or even a loose port so i need more info plz
Оценка 0
1 Комментарий:
sarry buddy i think u should take it to someone for a second pair of eyes u know what i mean i am limited by pixels lol but Ya that looks like it needs work
из
Добавьте свой ответ
Bryan Jimenez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 25
За всё время: 437
