What is the buzzing sound coming from?
Model no. LN37C550J1F
Hello, I got this Samsung tv for free so it’s no big deal but I would like to fix it if it’s an easy fix. After turning on, within about a minute it starts to buzz. It seems to be coming from the back. And when you put a bit of pressure on the power cable it gets a little quieter. I will include a video with the sound. Thanks!
Это хороший вопрос?
Оценка 1
1 Комментарий
I would suspect the power supply. Can you take the back off the TV and upload a picture of the power supply board? Adding images to an existing question
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@imac88 I am with @andrewsawesome on that. Sounds like a coil whine or transformer issue on the power board. Time to remove the back cover and take a closer look at the board. Post some good pictures of the boards with your Question so we can see what you see. Of course, do not touch the boards for as long as the TV is still plugged in. Even if it is unplugged, you want to make sure you discharge the capacitors before touching things .-)
Был ли этот ответ полезен?
Оценка 1
30 Комментариев:
How do you discharge the capacitor? thanks @oldturkey03
из
@imac88 You got it open? To discharge the caps I usually just use a large 10k resistor. To do it properly check on here For now you'll be safe just don't touch the components on the boards directly (for now)
из
I got it open. I’m being careful not to touch anything. Can you see the photos? @oldturkey03
из
I added photos, can you see them?@andrewsawesome
из
@imac88 no images. Use this guide Adding images to an existing question and you have to edit YOUR QUESTION. The images need to go there. Can't add images to comments.
из
Показать 25 больше комментариев
Добавьте свой ответ
FixItPlz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 35
За всё время: 2,908
