What do the Black Coax cables do?
While repairing my Pixel 4 XL I damaged the connector on the bottom black coax.
I had to perform a complete screen and mid chassis replacement which meant removing all the small circuit boards that were glued into the mid frame.
All of this went well but when it came to reconnecting the bottom black coax I misaligned the connector and must have crushed the tube that accepts the centre pin.
If you have a Pixel 4XL open and face down so that you can see the battery on the left hand side. This cable connects from the mother board to a support and then to a small printed wiring assembly in the bottom left corner of the phone. This assembly is held in by glue and a small screw at a diagonal into the midframe.
What I would like to know is what does my phone lose by not having it connected?
kind regards
Ruth
Это хороший вопрос?
1 Комментарий
Edit: Added 2 pictures to show the PWA in the bottom left and the connector that was damaged.
из Ruth Moreton
