Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
Это хороший вопрос?
Это хороший вопрос?
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
Был ли этот ответ полезен?
define "LINE IS GOOD" and how you know?
Is the scan and fax method is ON?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 23
За всё время: 420
2 Комментариев
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
из James Wildgust, Sr.
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
из bill
