Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
Is this a logic board problem?
Hi, ive been having problems with my iPhone 7. It's been having problems with connecting the lightning cable, and battery has been going flat quicky. I can always get it to charge by pulling out the cable, putting it back in, flipping it etc, and it will always work well with a new cable, but somehow I seem to go through a lot of cables quite quickly. They wear out or something.
Naturally, I thought the fix was that I need a new battery and charger port assembly, but before buying the parts, I have opened the phone, and there looks like there has been heat damage or something to the logic board. I was hoping the good people here would look at the photos and be able to tell me if it's a logic board problem or if it's the battery and charger port. Maybe it's a combination...
Anyways, here's the photos.
Thanks for any help. I figure if it's not the logic board, it's worth attempting a fix.
Это хороший вопрос?
Счет 0
3 Комментариев:
Could you take a look at your battery again, does it appear to be bulging at all?
из
I don't think so. Looks pretty flat
из
Image added (for the battery)
из
Добавить комментарий
1 ответ
If the board looks like that when you open it the first time, someone else has been messing with it.
Judging by the amount of dirt inside a supposedly water resistant phone, someone definitely messed with it before you own it.
The damage on the cable is unlikely to be caused by the board, it looks like corrosion caused by moisture.
Был ли этот ответ полезен?
Счет 0
5 Комментариев:
Thanks for the answer. I had the screen replaced a while ago.
Do you think the apparent damage to the logic board is water damage?
Can't really comment on the corrosion, I don't really know. but the damage seems to happen to certain pins and not the whole cable head
из
Have you tried cleaning your charging port with a sewing needle?
You will be surprised by the amount of dirt in there!
As for the battery draining ,the iPhone 7 series is getting to a age where there battery’s are going to need replaced
из
@Alexander There is no apparent board damage other than the torn graphite sheet. You can't see most of the board damage unless it is major mechanical damage.
For the cable pin damage. Moisture and electricity combined is required to produce such damage. Only those pins have electricity therefore only they are damaged.
из
Thanks guys.
@hellomacos. Yeah Ive done that. No good results really.
@tom chai. Thanks! Sounds like it's worth giving it a try. I think I will
из
Ah that no good is ,usualy that’s what I found works:-)
из
Добавьте свой ответ
Alexander буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 225
