The HP 15-bs115dx can be identified by its model number: 3MP96UA. It was released in 2018. It has an Intel Core i5-8250U processor, 8GB of RAM, and a 1-Terabyte hard drive.
Вопросов 2 Показать все
Which screen is compatible with hp 15-bs110ne
hi , I'm surprised that my laptop model wasn't on the list or mentioned in any way
"hp 15-bs110ne" , I have many white spots on the screen as a result of cleaning the laptop with "D-40 Specialist Electrical Contact Cleaner" , I've only sprayed under the keyboard
But apparently, after leaving the laptop for 72h to dry, the liquid has escaped to behind the screen and made white spots.
Now I'm trying to fix the screen if that is possible or replace it as the last case
could you please tell me if that is fixable? if yes how ?
if it's not fixable, could you specify which hd display 5.6in that would be compatible with this specific laptop ?
thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
its not repairable, take the lcd panel out and there should be a model number on it
Был ли этот ответ полезен?
Оценка 1
Hi @mymyit
Here's the maintenance and service guide taken from this support webpage for the laptop.
Go to p.72 to view the necessary pre-requisite steps and then the procedure to remove the display assembly to get to the LCD unit.
Go to p.23 Item #3 to view all the compatible LCD units and their part numbers. Search online using the part number only to get results for suppliers that suit you best. The part number should be somewhere on the back of the LCD unit in your laptop, if you wish to verify that you're getting the same one.
Оценка 1
Добавьте свой ответ
SmartIt будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 136
