Battery Replacement iPod Nano 4th Gen
The battery backup is only 15 minutes. Where can I find replacement battery (original or third party)?
It’s a 350mah 3.7V Li-Po Battery (MPN:616-0407).
Can any battery with these specifications work for my iPod or I have to check its dimensions?
I live in India.
Это хороший вопрос?
Счет 0
1 Комментарий
Thanks OldTurkey for the comment. I am able to find numerous options in my country when I search for Li-Po 350mah 3.7v battery but am not sure every one of them will be compatible with iPod. So my question is do most Li-Po batteries with 350 mah 3.7v work with iPod or I need to check the dimensions as well? Unfortunately, I am not able to find specific battery (genuine or 3rd party) 616-0407 in India so was thinking of ordering generic ones with similar capacity and voltage.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Swati Jain the APN numbers is correct at 616-0407 You do not need the dimensions if you order by that number. Apparently a 616-0467 will fit as well. Since you are not in the USA iFixit sadly enough cannot send those batteries overseas. That means you would have to find a vendor that does. Ali express has those batteries as well and should ship to India. We can of course not speak for the quality etc. of those batteries.
Замена аккумулятора iPod Nano 4-го поколения
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
из
Swati Jain yes, the physical dimension of the battery for this model iPad is crucial. There is not much room for any variations. It is a tight fit at the best of times.
из
Добавьте свой ответ
Swati Jain буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 24
За все время: 591
