While working the system is overheating and turning off
13" MacBook Pro (A1706 EMC 3163) While working the system is overheating and turning off
How can I fix this issue ?
Это хороший вопрос?
Оценка
0
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 43
Lets see if we can better identify the problem
Restart your system and press the D key to enter into the onboard diagnostics. Did you get any errors?
Reference: Mac startup key combinations
I would also install a good thermal monitoring app like TG Pro as it will allow you (and us) to see more clearly what is overheating.
Given the systems age you also likely need a new battery. When a battery gets old it often needs more charging which in turn causes the power logic within the logic board to heat up. To get a better view of what's happening within the battery install this app CoconutBattery.
Take a snapshot of the apps main window for both and post it here for us to see Adding images to an existing question
Also what are you doing on your system - Workflow ??
из Dan
