nvme ssd i/o
I wanted to know if you have a video or instructions on how to repair the nvme ssd I/O? I lift it one time too hard and it lifted the pins from the board. But I placed some thermal pad on it and it was applying pressure to keep the pins in the board and was working for a while.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Ha Nguyen it does not look like there are any instructions for that available. We really would need to see what you have going on there. Going by your description it appears as if you will need to resolder those connections. Applying pressure will fail since the pressure you applied, will become less over time. The proper way would be to solder it. Post some good pictures of the damage etc. with your QUESTION so we can see what you see.
Adding images to an existing question - iFixit Repair Guide
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Ha Nguyen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 61
