Thermal Pad replacement thickness
Does anyone know the thickness of the thermal pads?
Это хороший вопрос?
Это хороший вопрос?
Unfortunately, I cannot find anything on the specific thickness of the thermal pad, but I did find an article on finding the best fit for your GPU. I'll link it here for your viewing, but I'll give you the spark-notes of it.
Ideally, you should use the thinnest thermal pad that you can with the device. Start with a 2mm thermal pad, and if it has an indentation from the heatsink go down a size of thickness. The material that you use also matters, as some materials dissipate heat better than others.
Был ли этот ответ полезен?
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 80
За всё время: 3,950
