Released in 2013, available in capacities between 500GB and 2TB. Model numbers appear to be V73600-x where x denotes the capacity.
1вопросов Показать все
Is there any method to reapire Toshiba Hard drive
I have been using Dell Laptop for many years. Yesterday it's hard to drive stopped working.
I have some important data on my hard drive? Is there any way to fix my Hard drive? I checked my laptop it is a Toshiba DT01ACA200
Please it's urgent. I cannot do anything without my data.
Это хороший вопрос?
Оценка 0
1 Комментарий
Don't know if you fixed it already, if not you could also consider following this troubleshooting guide(Hard Drive Troubleshooting) to hopefully get access to your data again, or even simply to explore the topic in more depth
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
its probably not something you are going to be able to repair yourself. if the data is really important then you should have an experienced technician look at it.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
jay m будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 175
