Третье поколение смартфонов Google Pixel и их первый телефон с «челкой». Оснащен OLED-дисплеем 6,3 дюйма QHD+ и накопителем объемом 64 или 128 ГБ. Доступен в цветах «Почти белый» (Nearly White), «Просто черный» (Just Black) и «Не розовый» (Not Pink).
Part for insulation tape?
Changing my battery due to the phone overheating and I noticed the insulation tape was torn. I cannot seem to find a replacement part for this anywhere. Can anybody point me in the direction of the part or a workaround to fix it?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi
I wouldn't worry too much about this tape as it docent appear to be connecting to anything,heres what I would do!
try your best to straighten it out and get some non-conductive tape such as sellotape or electricians tape to put on top any that should fix your issue the best I can be fixed as I don't know of anywhere that would sell you a custom cut piece of this type of tape.
if you have anymore questions please ask
hopefully this helps
Был ли этот ответ полезен?
Счет 1
7 Комментариев:
This is what I was thinking of doing but had one thing holding me back. That insulation tape seems to be connecting to a heat sink from the battery to keep the board cool. Will electrical tape be able to transfer the heat from the battery to that heat sink?
из Поделиться
@Justin O
I don’t think it would matter too much as tape is horrible for transferring heat(that sort of thing wouldn’t make a difference in a cooling system)when its that thin,I think the tape is more just part of the manufacturing process rather than a essential part of the phone so the electrical tap will do just fine:-)
из Поделиться
Thanks, going with the electrical tape for this!
из Поделиться
@Justin O
That great:-)
из Поделиться
I tried using some metal foil tape, thinking it would conduct heat better, but now my GPS isn't working. I think the foil is shielding, reflecting, or otherwise interfering with GPS satellite signals. So don't use metal tape!
из Поделиться
Показать ещё 2 комментариев
To anyone else watching this thread, this isn't regular tape. This is a graphite thermal pad.
Счет 0
Добавьте свой ответ
Justin O буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 33
За все время: 843
