Razer Blade RZ09-0102 — это 14-дюймовый игровой ноутбук, выпущенный компанией Razer в 2013 году. Его также называют Razer Blade 2013.
Why laptop is not turning on?
I have razer motherboard rz09-0327. I have checked the voltage lines, every voltage rail is present, when I press the button on the mother board fans spins, gpu and cpu get warm and everything shuts after approximately 5 seconds, but there is nothing on the diplay. And battery getting charged as well, I tested the voltage. There are no shorts that I could find. What might be the problem? Or where else I have to look?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @dmakhmammadov
Try a power refresh and check if that resolves the problem, in case it is a corrupted BIOS that is the cause of the problem.
  • Disconnect the charger if connected.
  • Open the laptop and disconnect the battery from the motherboard. (you don't have to remove the battery, just disconnect it). Here's a video that may help. Not your exact model but hopefully it is close enough to help.
  • Press and hold the laptop's Power On button for a full 30 seconds and then release it. This should reset the BIOS back to its factory default settings.
  • Reconnect the battery and reassemble the laptop.
  • Connect the charger and try turning it on.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Diyorbek Makhammadov буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 23
За всё время: 1,079
