Top load washer stuck locked
Having a lot of problems recently with it never finishing, and now stuck locked. Have recalibrated a dozen times. Usually just stops with wash light on with no water visible in it. Wondering if maybe drain pump clogged since it sees a lot of dog hair.
Это хороший вопрос?
4 Комментариев
Hi @noj111,
What is the model number of the washer?
из jayeff
WTW4815EW1 - Fixed the lock issue. Tried unplugging for an hour and still had problem, locked and could not cancel. Put back into manual diagnostic, then was able to unlock. Still fails constantly with wash light on, with clothes wet (not spun) and no water in it. I have 6 long hair dogs and wash their blankets frequently. Wondering if evacuation pump is clogged.
из Jon
Someone replied, but do not see post. Ran automatic diagnostic and comes back to Done. Does it return fault code or error codes?? If error code could be basket speed, no fill/slow fill, or long drain or a few other things. Totally confused if they are error or fault codes. Figures I finally need glasses, and hard to read microscopic print in manual. How do I get fault codes?
из Jon
Figured out the code issue. Once in diagnostic mode, turn knob till done light on, press start, all lights flash, turn knob once to see last error, first flash is fault, second flash is error.
из Jon
