Monitor problem HP 27xq
I have these light streaks that appear in some areas and disappear in the midst of the colors
I never erased the screen and I don't know what to do
And the problem frustrates me in some games when it appears
I want to point out that what I noticed is that these relics were in the form of menu icons for a game I played a lot ( Although it is not very clear, I made sure that it takes the same place and shape as the icons in this game ).
(It is noticeable that this defect does not appear in the five colors R-G-B & Black & Withe = with app UDPixel)
Это хороший вопрос?
3 Комментариев
Hi @kinglords
Can you try another monitor to prove whether the problem is in the display or perhaps the computer, GPU for example?
Does it only appear in games?
из jayeff
@jayeff
First, thank you for the reply.
- I used another computer with this display and same problem
- I changed the cable from Displayport to HDMI since I relied on Displayport a lot (same problem with HDMI ).
The problem appears all the time, but it is noticeable that the longer i use the screen, the more lines appear, which are basically, as I said, words and icons of the things that I use for a long time.
из kinglords
I have the same issue with mine, thought it was something I had done... And its out of warranty now too :(
из Atomical
