2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274вопросов Показать все
Diagnose why laptop won’t charge
I am not getting a green light on my MacSafe adapter and my computer will not power up. It thinks it is plugged in because when I hit the power button it displays the empty battery symbol with a lightening bolt, but no plug
I replaced my power supply and batteries a couple of years ago so I am suspicious the problem is somewhere else. Is there a way to determine whether the problem is in the MagSafe board or the logic board?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из
Добавить комментарий
1 ответ
It could be a internal issue. Most probably liquid or moisture damage on the logic board. as it is quite old model, this is very common in macbooks. its better to get it diagnosed by a technician. i have repaired hundred of macbooks with this problem.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Sara Shoemaker будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 25
