*NVS 135M D630* - how do I know if mine has the revised or bad GPU?
I received this laptop in exchange for removing and destroying the original hard drive, as the previous owner didn't want to try and sell it and knew I know how to pull the drive and dispose of the drive right. However, I checked the BIOS and found a red flag: it has the Quadro motherboard :-(. While I'm still totally okay with using it (even if it doesn't last very long), how can I quickly tell which GPU mine has without opening it right away? There were no outward clues it's a Quadro board like power demand differences; I checked it against the GMA950 D630 I used to retrieve data from floppies for someone. You need to check the service tag on a lot of these Dell laptops to know (or know, like if that model was commonly setup with a GPU like the XPS M1330) and at the time I was more worried about getting it back and dealing with the hard drive since I could tinker with the laptop on my time.
At this point I might as well just throw a cheap SSD and a copy of XP on it and see how long it lasts. I don't think it will, but I can retrieve the SSD.
New info on the GPU; I also did some research on this and the laptop has the A12 BIOS; this reportedly means the repair was done. In addition, this is the GPU info:
Это хороший вопрос?
2 Комментариев
Okay, you've confused me!
What's the question?
из Ben Capehart
@beanman56 I need to know if this D630 has the "bad" GPU which fails, or the "safe" revised" GPU.
The D630 has a known issue, and I didn't know it had the infamous lawsuit GPU, initially; most of these D630's are GMA950 based, which do not fail.
из Nick
