Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
25вопросов Показать все
How do you download video from a Flip after power loss?
I have a Flip camera with the files "locked" in the camera after it was (rather brutally) powered off by accident. The camera still comes on and indicates the files are there, but will not download them. The last few seconds of video should be awesome as the camera 'Flipped' out of a race car at about 90 MPH!
Это хороший вопрос?
Оценка 0
2 Комментариев
This question was migrated from http://meta.ifixit.com/Answers.
из
When you plug your Flip into the USB, does your computer still recognize the camera?
из
Добавить комментарий
1 ответ
Выбранное решение
When this happens, it's usually a filesystem corruption issue or a failsafe done by the Flip camcorder to protect the camera. More then likely the corrupted file causing the problem is a lost cause and won't ever be readable, but it may be possible to repair it if you really need it back.
Plug the camera into your computer and download the video as a precaution. Once that's done, scan the filesystem and see if there's a problem. If there is, it will be corrected if there isn't a problem with the flash memory.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Ted Baber будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 895
