Repair guides and support for top and front loading Whirlpool brand washers.
425вопросов Показать все
Top load whirpool problems - WTW4815EW1
Have any problems and can not figure out. Just fails to run, once it starts making spinning or agitating noise. Does not seem to completely empty. Have drain pump off now. Should impeller spin freely?/ It builds up tension then moves. Any other tests I should do while accessing the bottom?? The belt looks good and it and tub spins, The agitator does not spin freely, but spins with tub. It failed basket speed test and I think shifter test. Can confirm when i hook it back up.
Update (08/02/2022)
Replaced speed sensor assembly and works.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @noj111
This machine has certainly been giving problems over the last 12 months.
Maybe check if the drive pulley is OK.
If you're still getting basket speed fault and shifter fault error codes, see Test #3 Drive system tests on p.13 of the tech sheet that you have.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks!! Was just reading through that, and will do multimeter tests. I tried tachometer test and does nothing, Will rule out main board and harness. Should have written down sensor part number when I had it off.
из
@noj111
I thought that the speed sensor was part of the shift actuator assembly but I might be wrong.
The part number for the actuator assembly is W10913953
из
Добавьте свой ответ
Jon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 181
