Curved line under screen
There is a curved line under the screen. When I touch the screen it does not feel cracked. It goes away when I turn the computer off. What’s the problem and how do I fix it. Thanks!
Это хороший вопрос?
Это хороший вопрос?
Retired Mac repair person – doesn't mean I know everything, but that I've done a whole lot of repairs and have seen things.
Your display has layers, the glass being only the part closest to you. There's an interesting teardown of the retina display here on iFixit, and if you want to geek out, you are welcome to read it. My point is that things can happen other than cracked glass. If your computer were on my bench, I would:
Because that line is semi-circular, I will take a wild guess that someone sat on your Mac and – realizing their mistake – jumped up before it showed any obvious dent in the case. This would flex one or more of the inner layers and create a butt-shaped "wrinkle" in the display. However, I would also not be surprised if a small wire had come loose and was hanging down instead. If I were to place a bet, though, it would be on the Butt Damage option. It would mess up the display without necessarily causing a crack in the glass. And it would disappear when the computer is off (but see option #3, above).
In any case, if this is showing in all apps and Finder, you are looking at a physical issue which will likely involve replacing the display. Taking those displays apart is a royal pain in the part of the body I think sat on your computer, and such "repairs" often end badly.
Был ли этот ответ полезен?
@willardroad has given a detailed, thorough answer that I whole heartedly agree with. Try the steps outlined above and let us know what you find.
The bad part is that, for us "normal" people doing our own repairs, we pretty much have to consider the MacBook displays as unrepairable; as mentioned previously, it is extremely difficult and undoubtedly requires specialized equipment to disassemble a MacBook screen.
The only thing that leaves us is the replacement option, which of course can get expensive. A used display will usually be the cheapest option; eBay is probably your best bet for that. Otherwise it may be possible to get a new replacement part at a semi-reasonable price on something like Amazon, AliExpress or even eBay.
Good luck, and keep us up to date on how it goes!
Writing to agree with Jerry and add a bit more.
Years ago, I ran an Apple Authorized Service Provider where we tried to fix everything that came in the door. We were the only repair facility for many miles, so we got loads of repairs... some of which we should not have even tried. Mac laptop displays fall into that category, but like a buncha dummies we kept trying. Sometimes succeeding, but mostly failing.
The reason: Apple's laptop displays are fabulous... and fragile. When they work, the colors and clarity are magnificent. When they don't, or when something stupid happens like sitting on one, or packing it too tightly in luggage, the displays get hurt and are an absolute nightmare to repair.
Here's a tidbit: To remove the bezel of any older MacBook Air, those wedge-like ones, required the use of a heat gun, oven mitts, and special shims we had to invent because none existed at the time. And frequently failed anyway. Totally not worth it.
I love Apple products, but repairing displays? Not so much.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 228
