Why is help displayed in the camera data display window?
After installing a fresh battery the word "help" is displayed in the data display window of the camera. There is no function when the shutter release is pressed, no film advance nothing is working.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @cuzz
According to p.94 of the user manual, help indicates a winding motor problem.
The solution offered is to remove the battery and then re-install it.
What is the battery charge being shown by the 4 bar indicator in the data panel when you turn the camera on?
Just verifying that you installed a 2CR5 Lithium battery? Maybe check the voltage of the battery. It should be 6V. The shutter is locked when the battery has been depleted.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Daniel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 16
За всё время: 519
