Repair guides, disassembly, and troubleshooting information for the 7th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in September 2019. Identified by model number A2197.
Requesting iPad 7 WiFi NAND Area Diode Mode Readings
Hello Everyone!
Please help me with iPad 7 WiFi NAND area diode mode readings.
Thanks!
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
On the chance that you still haven’t found this yet, I use this website for Diode mode readings often, but it’s only really got connectors. So not NAND. But I have a spare known good of this model, I will see what I can get for you in the morning,
https://logi.wiki/index.php/iPad_Diode_M...
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
@flannelist
Thats amazing!
I was trying to find a schematic for them but could only find payed ones that didn't come with a board view files and only schematics
il let them know you have solution
из
@flannelist thanks a lot, it will be very helpful to get readings from good board. @hellomacos
из
Hi
Do you have a schematic for it?
If you do that schematics tell you the size
Or
If you want to post some photos using this amazing guide
Adding images to an existing question
I could use the photos the photos to try and tell what size they are
Hopefully this helps
Any questions please ask
Счет 2
17 Комментариев:
I don't have schematics. I want to check on logic board if NAND points are properly connected to other areas. hence I want to know diode mode readings for NAND area.
из
@hellomacos I don’t think it’s about the diode but checking for a short on a circuit in diode mode on your multimeter check on here for the how etc
из
@v1ny4
I see
I would check places like the badcaps forums for schematics as they’re a few for a verity of models on there on there
When you said measurements I thing you meant measurements like 0402 0201….
Il have a look my self and see what I can find
Also what is the Board number you are working on?
из
@oldturkey03
I just realised that
I though they were on about components sizes because he said measurements in the original post
Thanks for letting me know:-)
из
@hellomacos my bad, sorry
из
Показать ещё 12 комментариев
Добавьте свой ответ
Vin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 937
