How to charging point
how to fix charging pin
Это хороший вопрос?
Just buy a new charge port, comes as a complete board. Just open the phone and swap it over. No soldering involved.
Был ли этот ответ полезен?
Hi
Unfortunately you can’t really fix a connectors pins without replacing the whole connector as they are very small and it could be too far gone
You will have to solder on a new one to fix the issue or replace the board/cable if it’s attached to one
If you post a picture of the inside using this amazing guide I can confirm that for you as it could just need cleaned rather than replaced:-)
Adding images to an existing question
If you need any help let me know
Hopefully this helps
Any questions please ask
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 298
