The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428вопросов Показать все
Chip pxd 843 is the same as the chip pxd 031?
I recently bought this tiny chip, but I'm not sure if they are the same, for the numbers change. My original chip is pxd 843 and the one I recieved is pxd 031. Are they doing the same job? No matter those numbers?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Angie Palomino we really would have to see what you got there or at least where it sits on your board. Post some good pictures of the part and it's location on the motherboard. That way we can try and identify. It is possible that it does the same thing and may be interchangeable.... PXD should be a DC-DC converter but unless we can see it we can only guess. So take some good pictures go to edit your QUESTION and use this guide Adding images to an existing question to add pictures.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Angie Palomino будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 30
