Logitech MX Master 3S get wet!
Logitech MX Master 3S get wet and stop working. I have disassembled few times, used electronic cleaner for all boards but no success. Charging light always red regardless how long I am charging. What to do?
Это хороший вопрос?
2 Комментариев
Thanks for suggestions. I did everything: remove all boards completely, cleaned all visible spots that possibly from water. But I have used CRC brand QD Electronic Cleaner. My concern about lithium battery. Its label says 4.2V, but can be charged up to 4.1V only.
Do I need to replace it? Again, regardless how long I am charging - red light (mouse indicator) always present, not green.
из Igor Vysoc
Igor Vysoc that voltage is ok. But it is not enough to test the voltage to prove that the battery is okay. If it got wet etc, I would replace it as well.
из oldturkey03
