Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
Digital Crown replacement procedure
How to replace Digital Crown?
My digital crown watch is all time crazy, so Watch is generally few usable.
I have to disassembly until housing completely, and then, get out digital crown, right?
Could be get out the crown before back glass?
thanks!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sadly you do need to remove both the the SIP and sensor array assemblies to gain access to the crown mount to remove it. But you could see if using some 90% reagent isopropyl alcohol to flush the sensors and crown pin.
If you've never worked on watches you might want to just let Apple do it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Antonio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 1,064
