Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
110вопросов Показать все
Removing a screen set with epoxy - tool advice needed
I know I screwed up big time, but here it goes.
Two years ago, I had to replace a screen on my S4. The replacement went fine. However, I did not have B7000 glue on hand. Feeling impatient, I used epoxy to set the screen. The repair held up fine; the problem is now I need to replace the battery.
What good prying tool would you recommend to dig through a layer of epoxy between the screen and the body of the watch? Of course, there will be acetone involved.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Vladislav Ekimtcov some isopropyl alcohol in a syringe with a blunt needle to try to soak the epoxy. After that some heat and the smallest dental pick you can find to try to gently scrape away the epoxy. It'll take a ton of patience.....
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thank you! Did not think the heat would help with epoxy, but seems like it will. How hot does it have to get?
из
@Vladislav Ekimtcov just try to get the epoxy „Tacky“ don‘t try to melt it since that may cause more damage. You‘d have to experiment a bit, so start with low heat. More of a steady warm…
из
Добавьте свой ответ
Vladislav Ekimtcov будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 32
