Absolutely no signs of life, unsure of what to do
even while plugged in, it shows no signs of life. I'm looking for some answers as to what the culprit might be.
Это хороший вопрос?
Это хороший вопрос?
In situations like this it's always best to start with the basics. In your case, I'd think you might want to start with, does it have power? If there's a problem with getting power to the battery to charge it, obviously at some point the battery is going to die and you'll be right where you are.
So first thing I would do is make sure you're getting power all the way from the wall to the motherboard. You'll really need a voltmeter for most of this if you have or can borrow one.
EDIT: Ah, I actually found a set of schematics!
Pins 1 and 2 should be the positive voltage, and pins 4 and 5 will be ground. So measuring between either pin of the positive pins and either pin of the negative should give you that same 16.5V you saw at the magsafe connector.
Let us know what you find and we'll go from there.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 75
2 Комментариев
When you say no signs of life, are you getting a light on the charger?
из Alisha C
@flannelist Yes, but the MacBook itself shows no signs of life. it doesn't do anything when I press the power button.
and the charger itself quickly flashes green, and then a steady orange until I unplug it.
из nikodoge99
