This guide will give valuable information in regards to the Maxwest 7360DC. The guide will include How to change the screen and battery.
1вопросов Показать все
Maxwest Uno M6 3G battery replacement?
Hello,
Does anyone know where I can get a replacement battery for a Maxwest UNO M6 3G phone? An unbranded battery is fine.
Thanks,
Josh
Note: The device selected for IFixit forum is not correct; They did not have the UNO device listed under the dropdown.
EDIT: added images of battery
Это хороший вопрос?
Оценка 0
1 Комментарий:
@mpm166 might be easier to search for by the battery itself instead of by the phone. Let us know what numbers are on the battery or post some pictures of your battery with your QUESTION. That way we can see what you see. Adding images to an existing question
из
Добавить комментарий
2 Ответов
This one seems hard to find. I'd go to the horses mouth and ask what they call their expert. Go here and click on the Ask Expert button:
https://usermanual.wiki/MAXWEST/UNO.User...
Был ли этот ответ полезен?
Оценка 0
@mpm166 do a search be the standard number. Since we do not have the dimensions for your battery and do not know how many contacts it has, check something like this I am pretty convinced that MaxWest does not produce their own battery, so they will most likely be rebranded.
Оценка 0
Добавьте свой ответ
Josh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 130
