Or just worth buying another Mac?
Fun fun- fricken coffee spill on keyboard- Any fix? Or just worth buying another Mac?
Это хороший вопрос?
Это хороший вопрос?
The problem with these rMBPs is if the display gets trashed like this one, it tends to cost as much as a nice example from the same year in many cases, give or take. Newer ones tend to be uglier; displays somehow remain expensive for machines that depreciate faster than anyone who bought them new will admit. Sometimes you can get donor machines with a good LCD, but a lot of Retina "donors" need the LCD for this reason :/. Retina LCD repairs? This sells Applecare alone even for DIYers. The holdouts avoided a nightmare, but the people who bought them took the hit because they're hard to sell now because nobody wants these MacBooks.
If this is from 2016-17 (2018/19 are BETTER, but not fully immune), I'm just going to come out and say it: SKIP THE $$$ LCD AND RUN, SELL IT FOR PARTS! It's a matter of when (not IF) the keyboard turns into an expensive repair, and when it goes vintage (and Apple no longer does the free repair/has parts), fugetabout it; it's a donor; sell it and get someone to pay a very ridiculous price for junk while you can. If you're adamant about keeping up to date get a current M series MBP (13" for portability, 14/16"* for heavy use, both with at least 32GB of RAM and 1TB of SSD space). If you go used, push for a 40-50% discount.
*Please, please try the 16" in person! As someone who loved the 17" (and ran one until the bitter end, and pressed the matter until the M series 16" came out). They are monsters (5lb) and are not travel friendly. The 17" Unibody was 6.5lbs, we're only shedding 1.5lbs losing 1.5" of screen. Same monster of a laptop in terms of weight.
I'm not going to say you shouldn't at least try to find a new LCD, but don't get so invested in this you will not give up and pay more for a display than you would for a 2018-19 replacement system with 32GB (16GB for the 13")/1TB (SSD is soldered).
Ideally, try for an M1 used, or a current-gen M system new; Intel is on borrowed time. That said, I wouldn't pass up a deal; if you can score something like a 15" DG 2015 cheap, take it. You will not catch me with a 2016-19 since they're unusable without several dongles, and display issues the 2015 is not affected by. But at least get it with a 512GB SSD*.
*You technically CAN upgrade this on the 2015, but get at least 512GB if money permits. Apple's SSDs aren't cheap, so get one which will last.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 114
3 Комментариев
@oldturkey03 Changed it to the 2017 15"; this isn't a 2013. It's got the speaker grille profile of the 15".
The 2012-15 has the nameplate free LCD, this has a nameplate.
The revision hurts me a little, but I'm not going to sugarcoat it :(. I have yet to find a way to make lipstick and eyeshadow look good on the pig that is those early Butterfly MBs. BTW I tried the 16" M1... The P3 display in XDR P3 mode makes the LG displays used in the "old Retina" look BAD in comparison color wise. I can't see calibration even with a Spyder helping make the humiliating gap disappear.
из Nick
@nick - I’m not sure if this is correct, the 13” is very similar and I can’t see enough of the grills to really tell which this system is.
Mark, can you please go into About This Mac and tell us what you have.
из Dan
@danj I see a large keyboard spacing which is why I think it’s a 15”. I’m just taking a educated guess myself as well.
из Nick
