Выпущено 21 сентября 2018 г. Модели A1921, A2101, A2102, A2104. Доступен как GSM, CDMA / eSIM или nano-SIM / 64, 256 или 512 ГБ / серебристый, золотой или космический серый. (Произносится как «iPhone 10 S Max.»)
375вопросов Показать все
Replaced charging port, still rebooting
Yah so had a charging port panic full prs0 whatever you call it, i replaced the charging port, and nothing has changed, did i less up? Is it a bad part, is somthibg blocking the sensor? Please help, thabks guys (and gals)
Это хороший вопрос?
Оценка 2
5 Комментариев
Iphibe xs max
из
Nate dog, can you screenshot or copy/paste the text of the panic log so we can see what you see?
из
Yessir one moment
из
Jerry, do you have tellegram?
из
@natedawg22, no, I'm afraid not. I was suggesting posting it here so we can all see the text of the error message; there are several people on here who are very experienced in dealing with kernel panics who might be able to help.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If the issue is the PRS0 sensor, that’s the pressure sensor (barometer). It has a pretty recognizable appearance on the charge port assembly. When I buy these, I generally make sure I get them from reputable vendors, or ones with a documented warranty or return policy. I have seen shoddy cables of all sorts, but testing in a known good housing, or with a known good charge port would be a good start.
If it still does this with a known good, charge port, then you may be looking at a board problem.
iPhone XS Max Lightning Connector Assembly Изображение
Продукт
$24.99
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Ok question, for the little hole where the sensor goes, any adivce? How do i get it in there? Should i glue it in? Should it stick by itself? What glue? Should i be carefull not to do somthing? Thx boss
из
Also does the port flexes/black sheet stuff have to blue glued diwn in anyway for me to test?
из
Did you use an original chargeport? And try to disconnect all flexcables except the on/off flex. If it restarts, add one flex at the time until you found the problem.
Оценка 0
1 Комментарий:
Also where can i get an original flex cable?
из
Добавьте свой ответ
Nate dog будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 17
За всё время: 271
