6 Red Blinking lights (left side darker) on Sony KD-49XE8396
Hi,
I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
Many Thanks in advance.
Это хороший вопрос?
2 Комментариев
@watson306 failed backlights commonly do not create a error code (very few TV models do this). It could be a power board issue or a LED driver board issue. Post some good pictures of the boards with your QUESTION. That way we can see what you see, Adding images to an existing question
из oldturkey03
@oldturkey03 I've opened it up and took a pic of the boards I can see.
There doesn't appear to be any obvious burning on them.
But I can take a closer pic of them if you direct me where?
из Watson306
