When my ceiling fan rotates the noise is like type writer
When my ceiling fan rotates the noise is like type writer hitting sound . What could be the problem?
Это хороший вопрос?
Это хороший вопрос?
Hi Sethuraman,
I just went through this at my son's house; all of his ceiling fans were noisy in different ways; on two of them the blades were loose and just had to be tightened; the other one wasn't mounted well to the ceiling and had to be resecured.
So yeah, grab a Phillips screwdriver and tighten all the screws that hold the fan blades onto the motor. I'd almost be willing to bet that will take care of your noise.
Good luck; let us know how it goes!
Был ли этот ответ полезен?
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 62
За всё время: 109
Hi,
Does it also make the noise if you rotate the fan blades manually i.e. not by using the power?
Are any of the blades loose at all?
из jayeff
