iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
boot loop after changing back glass
before changing the back glass my batterie was 11% ,i puted the phone off then i started removing the back glass using heat gun i did not touch any flex cable just the wireless charging area was a little bit cut but no thing serious
after finishing i tried starting the phone but nothing on the screen i tried plugged in charger the phone stuck on boot loop ,i tried to remove the flex cable of the wireless charging,the camera, home button , front camera no thing happen
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If your iPhone 8 is stuck on a boot loop and is not turning on after replacing the back glass, there may be a problem with the flex cables or other components inside the phone. It is possible that the heat from the heat gun damaged one or more of the flex cables, or that the back glass replacement process caused other issues with the phone.
To troubleshoot the issue, you can try the following steps:
  1. Check the flex cables for any visible damage or loose connections. If any of the flex cables are damaged or loose, try carefully reattaching them to the motherboard.
  2. Try restarting the phone in recovery mode. To do this, press and release the Volume Up button, then press and release the Volume Down button, then press and hold the Side button until the screen goes black and the Apple logo appears. Then, release the Side button and follow the on-screen instructions to enter recovery mode.
  3. If the phone is still not turning on or is stuck in a boot loop, try restoring the phone using iTunes. To do this, connect the phone to a computer using a USB
Был ли этот ответ полезен?
Счет 5
1 Комментарий:
think you for your help after checking the phone component i found out that the nife i am using to remove the glass slipped in the wireless charging module and the to the batterie making i very little scratch in the batterie and that was the problem
из
you can use the program 3U Tools to fix the phone by using the recovery mode and then exiting the recovery mode using iTunes. which can help you with the boot looping problem. if that does not help it might be an issue with overheating or damaged flex cables from using the heat gun on the back glass.
Hope this helps,
Счет 3
1 Комментарий:
из
Добавьте свой ответ
heny jarraya буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 548
