Samsung Galaxy A10e — это Android-устройство нижнего и среднего ценового сегмента, выпущенное Samsung в феврале 2019 года. Его можно идентифицировать по номерам моделей SM-A102(U, U1, W или DL).
white screen Have an A10e
Have a A10e with like a white screen with horizontle lines what needs to be done?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi Shawn,
It's hard to say exactly what's going on with your phone without seeing what the screen looks like, but so far from your description it sounds most like you will need to replace the LCD display. We can probably give you a more definitive answer if you can take a picture of what the screen looks like. Here's a guide on how to add pictures to your question.
Adding images to an existing question - iFixit Repair Guide
That being said, I didn't find any written guides to replacing the display on your phone, but there are guides out there for similar phones such as the A10 and A10S.
If you do end up having to replace the screen, generally there are two ways to do it. You can replace just the LCD or you can buy one with the frame preattached to it. There are advantages and drawbacks to both.
LCD without frame
Advantages
  • Less disassembly of the entire phone required
  • Cost is usually slightly lower
Disadvantages
  • More fragile, so easier to break during assembly/disassembly
  • Needs to be sealed securely to the frame
LCD with frame
Advantages
  • LCD is preattached to frame, so less chance of damage in the process of removing and replacing it
  • Better structural integrity with a preattached frame
Disadvantages
  • Significantly more work moving all parts within the frame to the new frame
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Shawn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 26
За всё время: 292
