Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
Apple Watch display lcd
I try to repair an Apple Watch serie 5 , but some but something go wrong when I try to attach the lcd display to connector , there is a solution for know if is the lcd screen broken or the connector ?
https://drive.google.com/file/d/1Y-9mF3X...
https://drive.google.com/file/d/1eZnVucF...
https://drive.google.com/file/d/1eawCLGr...
Это хороший вопрос?
Счет 0
2 Комментариев:
Adding pictures of the back of the screen ribbons and the connectors on the board would help.
из
Thanks Nigel, i have added the photo
из
Добавить комментарий
1 ответ
Sadly your OLED display is damaged! It looks like you had a hard time getting it off as the displays edge looks damaged, but the worse is the damaged connector on the backside. It also looks like the ribbon cables are a bit tattered as well.
In any case you need a new display.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Can you recommend a site where to take the display with advantageous prices?
из
I had tried to separate the touch display from the lcd display…
But if you tell me this, I order new display.
из
@Leonardo Barbieri - You’ll need the full display assembly which includes the crystal, touch & OLED display. These can’t be gotten separately.
Sorry I don’t have any parts source anymore to recommend.
из
Добавьте свой ответ
Leonardo Barbieri буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 181
