Broken swivel on ear
Hd 450 bt. Broken ear swivel and cable has become longer so can’t glue it how do I get the cable back into the headband!
Это хороший вопрос?
Это хороший вопрос?
I have had this problem as well and believe I have found somewhat of a solution. You need to pry off the outside cap which is glued on after removing the 2 screws from the inside of the earpiece swivel. (The side which would be closest to your head if you had the earphones on) The cap with the seinheiser logo is glued on so I recommend using a heat gun or blow dryer to loosen the glue. Beneath there are two smaller phillips head screws.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 45
За всё время: 310
Hi
Could you add some images using this guide
Adding images to an existing question
Doing this will help us get a better idea of what’s going on:-)
из HelloMacOS
