Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
704вопросов Показать все
Nintendo Switch stuck in boot loop after possible water damage.
Some water spilled on my switch, mainly in the fan, and I dried it off but it got stuck in a boot loop. I powered it off and left it to dry for a while, and when I turned it back on it restarted fine, I was even able to start a game. However I wanted to let it fully dry in case there was more water that hadn’t dried. So when I tried powering it off, it got stuck in a boot loop again. So I’ve powered it off completely again and put the switch and the joycons in rice. Is the boot loop from possible water damage? Like I said it still turns on, but it keeps getting stuck in the boot loop. Both joycons work fine and don’t seem to have any damage.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
first of rice does absolutely nothing, it needs opened and cleaned with 99.9% isopropyl alcohol to wash of the minerals from the water. do this and then try it again or take it to an experienced technician
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Rice, always makes me laugh out loud.
из
Добавьте свой ответ
Aaron G будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 326
