The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
I accidentally spilled a small amount of water on my headset
I spilt a pretty small amount of water on my Meta 2 headset, it was working properly but now it isn't turning on. It still displays the powering on screen, but it won't stop. The controllers won't connect either, but nothing happened to the controllers.
Это хороший вопрос?
Счет 4
1 Комментарий
yeah same it keeps doing that i hear it turning on but its restarting in the booting screen
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
Just like with all water damage please don’t try and turn it on unless for testing purposes as it can make the issue worse:-)
What I would recommend doing here is taking the device apart and having a good look for where the water got in,the sooner this is done the greater chance you have of your device working again!
Once inside and you have find where the water has gotten in ,carefully clean the effected area(there’s usually corrosion where the water got in)with isopropyl alcohol until the parts and boards are water and corrosion free
After making sure no other parts were effected you can plug it in and test but if it still doesn’t work ,it will need board level repair which isn’t easy unless you have experience in that sort of field
Here’s a disassembly guide
Разборка Oculus Quest 2
And here’s a water damage guide(this one if a iPod but it’s the same process for resolving water damage)
Ремонт iPhone после попадания жидкости
Hopefully this helps
Any questions please ask
iPhone Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
Meta Quest 2 Oculus Quest 2 Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Karter Brown буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 1,159
