Guides and repair information for washing machines produced by Bosch, a German engineering and technology company.
Why is my washing machine not pumping water out (correctly)?
Hi, I actually have a Haier Inverter Motor 7kg front loader washing machine but couldn’t see it listed.
I’ve recently moved into a new house and noticed my washing machine pump wasn’t draining, and I was receiving a ‘clr fltr’ message. I initially cleared my filter, turned it back on and still got the error. I then opened up the bottom of the machine and checked for obstructions in the tubing underneath, nothing.
So I tried something, I disconnected my pump hose from the outlet under the sink, and ran the machine on a spin cycle, all the water came out quickly and without issue, so I’m 99% sure my drain hose isn’t clogged or obstructed. Is it possible somethings wrong with my plumbing? There’s no kinks in the hose however it does have to run down and then slightly up again to reach the connection.
Any help at all would be appreciated as I’m completely lost.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi,
What is the model number of the washer?
Usually the user manual shows how to install the hose.
This manual says to ensure that it is installed 80-100cm from the floor -see p.7
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Hey, that is the exact model number we have in the manual you provided. So the hose is supposed to sit over the sink? I have it attached to a port under the sink.
из
Hi @Samuel Campbell
No the hose is supposed to be connected to the drain if there is the appropriate fitting for it which you have.
Since it is a new house I assume that there's never been anything previously connected to the port in the drain pipe under the sink, is this correct?
If so check that there has been a hole drilled in the base on the inside of the port through to the main drain pipe i.e. so the water from the hose can flow into the drain pipe. Stick an appropriate length screwdriver in it and see how far it goes in. If there is a hole then it should be long enough to get to the other side of the drain pipe and not stop where the port stops on the pipe.
Usually with new plumbing fittings the ports in pipes are still sealed (basically the plastic side of the pipe) as you don't want waste water from the sink above coming out of them and flooding the cupboard in the case of a blockage in the drain's P-Trap, which is just below the ports. It is better that it rises up into the sink first where it will be noticed earlier. If there's a hose attached to them then usually it will be stopped by the drain valve in the washer or dishwasher, so again no flooding. It will still rise in the sink. This is of course as long as the hose clamps are secure ;-)
If there is no hole you will have to unscrew the pipe fitting and remove it and then using an appropriately sized drill bit drill a hole down through the base inside the port into the main pipe, clear out any swarf that may be still attached to the hole edge to ensure it has a clean edge so as to prevent any debris from catching etc and then reconnect the pipe back in again and connect the hoses up etc
из
Добавьте свой ответ
Samuel Campbell будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 28
За всё время: 452
