This may also help, if you don't already have them:
DELL Latitude X200 Service Manual
and
DELL Latitude X200 specifications
Rufus v3.21 and the USB port is your key.
Rufus download
The computer has a USB 1.1 port. USB 2.0 is backward compatible with USB 1.1so most USB flash drives will work.
All you need is an XP iso file to make a bootable Windows XP installer which Rufus will do.
Study how Rufus works and away you go.
Make sure that you download all needed drivers to the USB drive after running the Rufus. Amazingly DELL still has drivers on its web site. Bless their hearts!
DELL XP drivers
For your hard drive you could also use IDE to SATA or mSATA drive converter but your IDE to SD sounds good. I would experiment to see which is fastest. You could also use the CD drive bay - I'm assuming you don't have a CD/DVD drive which you could just use with the XP Pro install disk.
As an aside, for interest sake, I have a DELL Inspiron 6000 running Windows 10 using a IDE to mSATA converter. These mSATA drives are used on POS and gaming systems. They look like WiFi cards.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
