Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327вопросов Показать все
Is it safe to go back in?
Hello, ifixiters
I just replaced the battery on my MacBook Pro 15” Touch Bar 2017 using the magic kit. It was just like diffusing a bomb in the movies, I’ve never tread so carefully. I meticulously followed the instructions and feel 99% confident that I put everything back where and how it should be.
I reset the SMC and zapped the NVRAM. I tried every secret combination of key holding down. I get the chimes but no startup love.
I think the next step is to go back in and check all of connections that I unspudgered and respudgered but the pickle is, I have no way to confirm discharge of the new battery. Unless one of you fine folks has another suggestion, is it safe to go back in?
Much appreciated if you can help. There’s a special place in Hell for the ones who decided to glue these batteries in to begin with.
Please save me from chucking this faithful old girl in the recycling bin before her time.
Cheers,
Lori
Это хороший вопрос?
Оценка 1
3 Комментариев:
Where did you get the battery - magic kit?
из
The Fix Kit that ifixit sells.
из
@lbstgmgr - Got it! We get a lot of Q’s that can confuse without guessing.
из
Добавить комментарий
1 ответ
OK, Do you see any image on the display?
If you have an external display see if the desktop shows up on it (you will need to shut the lid to get it to respond).
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
No image and I don’t have an external display. Also not a brightness issue. Nothing responds or lights up on the Touch Bar or Keyboard. I thought maybe the Power button or Touch ID sensors were not completely reseated when I put it all back together. I wanted to go back in a check all of the connections but didn’t want to fry the Logic Board or myself.
из
@lbstgmgr - Did you find the loose connection?
из
Добавьте свой ответ
Lori будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 46
