Broken ring/halo ribbon assembly inside torn in half
Son broke his halo/ring, ribbon assembly that surrounds and connects everything inside ring is torn in half. My question is how can I find a list of internal parts to replace items like this? I cannot even find a diagram or schematics. That's all I really need then I can figure it out. Thanks in advance
Это хороший вопрос?
2 Комментариев
@swankyjrsgurl lets see what you got going on there. Post some pictures with your QUESTION. That way we can see what you see Adding images to an existing question
из oldturkey03
My son fell and smacked the left controller on a living room table. The Controller would connect and disconnect. The Meta Horizon app would detect the controller, but the laser wouldn't turn on. I took it apart and noticed the Left Ring connector for the Loop/Ring ribbon was burnt. The device appears and disappears as if there was a bad contact. It's not easy to test the ring ribbon because it has many sensors, and I am sure they have some resistance, but the Meter might use the 9 volts battery voltage for continuity test and might damage sensors on the ring ribbon. I found that after replacing the mother board and ring ribbon it might be cheaper to get a new controller from Meta for $75.00. If you use the good controller to test the bad one, then you also have the risk of static damaging the good one.
из Quintec2001
