Boosted's smaller and more affordable electric skateboard, released in 2018.
My battery is completely dead
BAttery has been run dead have tried various ways of fixing it but going backwards, a drill rotor, and treadmill have not worked
Это хороший вопрос?
Оценка 0
1 Комментарий
William Mcleod lets see what you battery looks like and the way you have it hooked up etc. Adding images to an existing question
Sure sounds interesting
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Should be a lithium ion pack inside it. If allowed to drop below a certain voltage the bmc board will not allow the battery to take any charge. Ideally you'll need a new battery.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
worst part is I did buy a new battery but it was the wrong model, then the seller ghosted me. Im just looking to get some value out of the board without spending another 300 dollars
из
@William Mcleod that is why it would be important to see what pack and hook up you have on this.
из
Добавьте свой ответ
William Mcleod будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 172
